P1
P2
P3
P4
Technical - Heavy Twins
 Bearings  Main bearings
 Carburettors  Carburettors
 Clutch
 Crankcase  Crankshaft balancing
 Cylinder Head & Barrel  Oil feed
   Oil leaks
   Tappets
   Tightening sequence - Method 1
 Exhaust & Silencers
 Frame & Swinging Arm  Steering head bearings
 Gearbox  Layshaft bearing conversions
   Oil leaks
 Miscellaneous  Dominator 'mix and match'
   Hints and Tips
   Hints and Tips - Dominator
   Piston rings - running in
   Sidecar fitting
 Oil  Cylinder head oil feed
   Leaks - cylinder head
   Leaks - gearbox
   Leaks - primary chaincase
   Oil - a treatise
   Oil - synthetic
   Oil pump - priming
   Oil pump - repair
   Wet sumping - anti-drain valves
 Primary Drive  Belt drives
 Suspension  Forks
   Fork action improvements
   Rear spring ratings
 Wheels  Alignment
   Bearings
   Rims & tyres
DTD Cover
2.4 Cover
V1.3 cover
Addendum Cover
Front Pic
