I have a mk3 850 commando, and would like to know the valve clearances when using a pw3 cam...please!!
The data sheet says 11 tho…
Suggest you speak to Norma…
Suggest you speak to Norman White. i think mine are set as standard ??
Hello,i have also PW3 cams…
Hello,i have also PW3 camshaft on my MK3 and Boyer ignition system,i am not sure does the timing working with PW3 cam as standart cam?.
PW3 Clearances
I want to see more of the detail in this thread / exchange but the hyperlinks just flick the screen and a new comment box appears. Very frustrating. Can anyone of the contributors respond to the thread to bring it back to life maybe? I have an 850mk 2a with PW3 fitted and see 11 thou recommended but for both exhaust and inlet, is that true?
Thanks for any advice.
PW3 Cam
I have this exact setting on my Mk2a, as recommended by Mick Hemmings in his Videos. No complaints from me ,except for the increased clatter, but "they all do that sir". One thing that has worked for me is glueing some shaped foam on the underside of the seat, directly above the tool tray so it presses down on the contents Stops it sounding quite so much as a bag of spanners!
The data sheet says 11 thou.
