For the rebuild of my '71 Roadster I've decided on 90/90 front and 100/90 rear tyres, both on 19" wheels. Tyres will be Avon Roadriders.
But I can't make my mind up on the front wheel width- WM2 or WM3?
I was leaning towards WM3 as it would allow a 100/90 in the future if needed, but I've read the WM2 might be a better option. Then Avon recommend the WM3 for the 90/90...........
The rear will be a WM3.
Any advice greatly appreciated- it's giving me a headache!
Thanks very much
Robin
PS- Sorry if this has been done to death already.....
I have the 90/90 WM2 and 1…
Dear Robin, A suitable com…
Dear Robin,
A suitable combination is WM2 Front and WM3 Rear with 90/90 Front and 100/90 Rear. You won't believe how much the handling is improved. For suitable tyre pressures try 32 Front and 36 Rear.
Best wishes, Colin Cheney, Leicestershire.
Thanks Richard & Colin…
Thanks Richard & Colin, that's really helpful
Looks like I'll be going with the WM2 front- the mudguard isn't an issue as I won't be using the standard one, plus I like the look of the smaller front rim anyway.
All the best, Robin
I have the 90/90 WM2 and 100/90 WM3 Roadrider set-up on Akronts. The 90/90 seems to sit OK on the WM2 but Avon do indeed recommend a WM3.
The tyre looks a little lost under the wide mudguard intended for the 4.10. Which guard are you using ?
Looks apart, this is the best handling tyre and rim combination that I've ever had.
small-jpg
