Mk.3 Commando CMA wheels
I have a set of cast alloy wheels that i bought last year that as far as i can research are CMA or Cambray made. I was told these had been on a MK3, having tried to offer them up i need some advice on the build up of the wheels because nothing seems to fit quite right, so i need ideally a drawing of the setup front and rear , if there is such a thing. See attached picture.
Cheers Ian
They are CMA wheels not Cambray. I have Cambray wheels and the bearing arrangement is pretty much the same as standard wheels. Sadly I can't help you with CMA but just wanted to confirm the maker of yours. Hopefully someone else will help.
Ian
Ian
Thanks for confirming the make. Nice to know for sure.
Kind regards, Ian
