Connections
Hi, I have not worked on my 1974 850 for a while and I have misplaced some wiring diagrams and my Norton workshop manual!
I bought a Mk 4 boyer and PODtronics rectifier/regulator and have wired them in. * Whast original equipment do I put in the bin? *Do I need more to get the bike running? * Do I need a Pazon or is it just another ignition system?
Many thanks Roger
Roger,
You'll no longer need the points, capacitors, ballast resistors, zener diode(s), rectifier. You don't need a Pazon as you have a Boyer.
Aslong as the rest of the bike is complete it should run.
P.S Try looking online for the Boyer and Podtronics wiring diagrams.
Regards,
Simon.
