Valve and spring kits
Afternoon all.  I have spent the last 6 weeks inventorying my parts, cleaning the cylinder head and removing rust for my 54 Dominator 88.  I believe I am ready to start rebuilding the cylinder head.  Are there complete kits out there that include the valves, springs, gaskets, push rods that you could recommend that I buy?, Europe or USA, doesn't matter.  Any advice is appreciated.
Jeff,
RGM have a cylinder head overhaul kit, part number050274 for pre 1963 models.  They also supply pushrods and gaskets.
I have read that the non DD valve springs are all the same , I have also read that there are 3 different springs . Do some research.
In reply to by robert_tuck
Thanks for the heads up, Robert
The chart below shows the Norton Dominator Valve Spring lengths over the years. The earliest are very hard to get from a stockist but there may be some New Old Stock around. Generally the later Dominator and SS Head Springs are the easiest to get hold of.
The SS springs are shorter but have thicker coils. They also had heat resistant washers under the spring cups which all of the various types will benefit from if fitted.
springs
