Can someone please tell me what size socket I need for the oil tank filter nut
thanks in advance
Year of bike ?
A 71 Roadster takes the…
A 71 Roadster takes the later oil tank. Two M26 Dowty washers will replace the copper or aluminium washers and provide an oil tight seal.
Download this PDF, get a…
Download this PDF, get a cheap digital caliper and you will never need to ask for the spanner size of a fitting again, plus be able to see the close enough sizes that could work if the exact spanner size is not avaiable.
https://www.crawford-space.co.uk/old_psc/spanner-jaws.pdf
Combine that with a Thread gauge for £8 to £10 and you even get to see what abominations the Dump previous owner has inflicted on your bike with retapping to different threads.
Thanks John, I already have…
Thanks John, I already have a digital micrometer but I can’t get it in to measure the nut which is mangled anyway and needs to be replaced
Year of bike ?
