I have a Commando MK3 1975 in red does anyone know the name of the Colour
or the colour code Peter
Candy Apple Red, colour…
Peter, I don't know whether…
Peter,
I don't know whether you're looking to purchase paint but the colour can be found by clicking the link. I have used their paint-not cheap; but very good quality
Norton Codes
1973, 74, 75 code
02-fireflake golden bronze-no trim
022-fire flake golden bronze-double line trim
06-solid canary yellow-no trim
11-solid tangerine-no trim
13-white-no trim
130
14-blue(solid)-no trim
141-blue-silver single line trim
15-candy apple red-no trim
15-interstate red
152-candy apple red-silver double line trim
04-fireflake royal blue-no trim
042-fire flake royal blue-double line trim
09-black-no trim
091-black-gold single line
092-black-gold double line trim
163-white/blue/red
170-metalic silver-side covers no trim
172-metalic silver-black/red stripes  75-IS tank
Candy Apple Red, colour codes did not exist at the time, at least not in a modern form, but Candy Apple Red is a very common colour even today. Candy paint is a method, first you paint a base colour eg silver of gold followed by a number of coats of a coloured transparent lacquer which allows the base to still show through. It can be copied by going for a metallic but that will miss out the effect of the sun falling at different angles on the paint causing changes on how the base comes through. The number of coats of top lacquer changes how deep the colour is so even if you have an exact copy the thickness and number of coats need to be matched.
At the time the colours were badly affected by the sun and lost the effect, modern candy's are now colourfast and also you can add a 2K clearcoat for further protection.
