Description of Part Required:- Centrestand
Model Number required for.:- 1956 ES2
Part Number:- H12/524
Also used on if known.:- Not known
Implication of lack of part:- Pattern, substandard, or non-Norton part only available.
Routes you have tried to acquire the part and response received.:-
1. Contacted Norvil. ‘We don’t stock it because the owners club do’.
2. Is listed on club spares list but zero stock. Situation for the past two years
3. Contacted NOC spares in Nov 2018. ‘Maker is ill’
4. No further response to enquiries of NOC Spares.
Do you have a worn or damaged part available as a pattern?:- No
Based on price for similar parts, what would you expect to pay (give range)
Is listed at £116.00 +VAT and carriage on NOC spares site.
new centre stand
I had the same problem, but solved it by buying the centre stand described as for plunger models in the NOC shop. It has the same dimensions and just needs the peg for the spring grinding off, then a stirrup forming around the cross rail so you can attach the spring in the middle.There is a stirrup in the parts list for featherbeds which may do if making things isn't for you. The stand is a bit more expensive, but if you need one it works
