Can someone explain the little adaptor thingy found joining the long oil tank hose to the short oil tank hose on my 74 Mk 2a ? I have recently had the engine rebuilt but as far as i can see it doesn"t have one . Should it. Should i worry? Thanks , Worried of Wiltshire.
The only 'adaptor thingy' I…
I"M Adaptable
Still no explaination as to what the thingys for In my 850 parts book its called an "Adaptor" ,is that American for "Reducer"? Anyway, if any bodyknows what its for, I would welcome an answer. Thanks
Have you got a photo Alec or…
Have you got a photo Alec or a part number?
dan
The pre mk3 oil tanks had…
The pre mk3 oil tanks had two 3/8" spigots on top so the 1/2" crankcase breather pipe needs an adaptor 062617 to fit it - any old garden hose reducer will do plus a piece of 3/8" pipe. The mk3 tanks had one 3/8" and one 1/2" spigot so no adaptor was required
Do you mean #46 in this…
Do you mean #46 in this picture ? In which case I think your question has been answered.
The only 'adaptor thingy' I can think of is a reducer in the breather pipe to go from 1/2" at the crankcase to 3/8" on the oil tank. There was also a T-piece for the chain oiler, can't rember which line that weny in. Failing that you'll have show us a picture.
