Fired up the bike today after the top end rebuild, and registered 25 psi oil pressure cold at the l.h. rocker oil feed banjo bolt at tickover. Is this ok does anyone know?
Fine as long as it increases…
Fine as long as it increases with revs, 10 psi per 1000 revs is the lower end of acceptable with fully warm oil, max is set by pressure release valve and should be set for 50 psi, cold oil will make this higher.
