Hi all, need to adjust rear chain and believe the best way to set rear wheel is a straight edge from front wheel to rear, any other suggestions,?
Laser Spirit Level
Axle stands
To get the centre stand out of the way I use axle stands under the footrests. It also allows some of the weight to be on the rear wheel when you're checking the free play.
I use a spirit level with a laser beam in it. Surprisingly cheap too. Hold the level against side of tyre and shine beam forwards on to floor at side of front wheel. Do it on each side of the tyre and you will see straight away if the wheels are in line.
Ian
