SMITHS DIGITAL ELECTRONIC SPEEDOMETER
Hi there
I have recently aquired a 1975 mk3 850 Norton Commando it is fitted with a Smiths electronic speedo that is powered by a HALL sender unit driven by the original Norton rear speedo drive.On driving the bike i found the speedo did not work ,so i bought a new HALL sender unit from Smiths and attempted to fit it to the bike however the new sender cable has a brass box section sleeve that slides on to the sender unit, the old one has no such brass sleeve,Can anyone tell me what the brass sleeve is for ?.at first i thought it was to immitate the speedo cable but it will not fit in the speedo drive shaft as it appears to be the same size can anyone help
kind regards Steve.
