Paint for barrels/clock housings/brackets 650SS
Hi everyone,
what paint do you recommend for the barrels on a 650ss should it be gloss, matt or satin?
also what finish should the clock bracket and clocks be?
Many Thanks in advance,
Tom
When they were new, it was gloss for everything. Matt looks wrong and doen't give the same protection.
Hello yes Black gloss is the right , you may get it from Granville paints Yours AJD
Maybe black gloss is "right", but I use satin spray paint, (as used on wood-burning stoves) this never chips, and radiates away heat better than gloss. John.
Norman White has his stove enamelled in gloss black - so that's what I'll always do. Apparently matt black is better at heat dispersion but, as you say, it doesn't really look right.
Cheers, Lionel
