i have a two pin (male/female)hanging down near the heat sink on r/h z plate heat sink ,cant see it on wiring diagram ,any thoughts please it has same connection as my solat charger could it be ??rgds steve
Guessing without a pic but…
The only definitive answer…
The only definitive answer would be to trace the wires back and see where they go. What colours are they?
Since you mention a plug a…
Since you mention a plug attached to the bike's wiring I take that this is not the standard accessory plug (which together with the relevant socket wired direct to the battery is part 06.2099).
https://andover-norton.co.uk/en/shop-details/15933
A 12 vdc power takeoff soc…
A 12 vdc power takeoff socket mounted down close to the r/h heat sink was standard on at least 850 Commandos - my Mk 1A and Mk 3 both have them as fittedfrom the factory. Useful for battery charging or powering an inspection light.
Connect a meter to it to f…
Connect a meter to it to find out if or when it is live. I have a connector that I use for connection to the battery charge and when not charging to power Sat Nav. Also used to check battery condition and charging.
Never seen the 12 vdc sock…
Never seen the 12 vdc socket shown on any Commando wiring diagram despite being a standard fitting on 850's. Modern replacement Commando wiring looms don't seem to have the socket circuitincluded either. Socket remains live all the time and the two female socket holes are different sizes to protect against wrong polarity connection - you therefore need the correct male plug with pins of different sizes.
Previously james_fanning w…
Is this the socket and plug you refer to?
https://andover-norton.co.uk/en/shop-details/15933/accessory-plug-and-socket-06-2099-
Previously gordon_robertso…
That's the one. Both my 850 Commandos had them fitted as standard from the factory.
Auparavant james_fanning a…
Auparavant james_fanning a Ã?crit:
A 12 vdc douille de prise de force mont� vers le bas à proximit� du dissipateur de chaleur r / h est standard sur au moins 850 commandos - ma Mk et Mk 1A 3 ont tous les deux comme mont� à l'usine. Utile pour charger la batterie ou l'alimentation d'une lumi�re d'inspection.
Since 1970 for alls commandos. https://andover-norton.co.uk/en/shop-details/15933/accessory-plug-and-socket-06-2099-
7 people reply but no answ…
7 people reply but no answer from the Original Poster as to whether the question has been answered or more info is needed.
If you are going to ask people to give you info in their free time have the courtesy to respond even if to say the info is wrong.
sorry been in hospital,but…
sorry been in hospital,but that plug from the norton shop isnt it this one has a male female connection so you cant miss connect it as i mentioned just like the one fitted to my solar charger,again sorry for not replying, by the way my battery seems to be over charging 14.5 v ???this would damage battery ???? ill also get a pick asap again thank you for your help and again sorry rgds steve
Apology accepted! But as I…
Apology accepted!
But as I mentioned in my earlier post the only certain way to find out what's going on is to trace the wires back. Trial and error can lead to the release of quantities of Mr Lucas's smoke.
14.5 volts is fine for the charging circuit but should not go any higher.
thank you for reply so 14.…
thank you for reply so 14.5 is ok?? thought that may damage something but if you say its good when i get some strength back i shall give her a ride then ill try to post a pic of the plug again didnt mean to be a problem or expect to not return from poole hospital thanks everyone for your time rgds steve
+ 1 on all of that â 14.5…
+ 1 on all of that â 14.5v at the battery, with the engine running fast enough to produce the juice, is just what you want â I get the same, on both my MK2A 850 and on my Triumph Herald car. With everything off you want around 12.5v across the battery terminals for a healthy battery.
If your dangling connector shows 12.5 across its terminals with everything off, then it's someone's attempt to replicate the original accessory/charger connection. That was unavailable for many years, until fairly recently, so it wouldn't surprise me if someone's improvised.
And I hope you get well soon!
Previously Colin Peterson…
thank you for the charging info i did chase the wires, as you mentioned ,it was a power take off /charging plug luckily my solar charger has the same plug, but oddly both the wires on the other end connected to same terminal ?? now i have them on either terminal so i dont have to remove seat to charge battery which is nice ,as for getting better it may be a while just had 9 weeks chemo/rad all very nice not !!
What â both wires were co…
What â both wires were connected to the same terminal?! It sounds like someone tried to improvise, but didn't have a clue what they were doing! That, or maybe it was a wrinkle to de-activate the connector without removing it, if that terminal was the earth terminal â? Good news and well done, anyway!
About the chemo/rad, and to paraphrase Peter Cook, there are many things that I'd have left out, if I'd been thinking about creating the universe â? Good luck with it and, of course, best wishes.
Guessing without a pic but maybe a previous owners addition for charging battery without taking side cover off, I had pig tail extensions included with a slow charger I bought.
