Norton Head
is there a special socket to get the middle bolt out because it not thick enough to get the socket on I had a problem to get it out
Previously Tony Ripley wrote:
Hi Colin,
I think this is the one you need:-
http://www.rgmnorton.co.uk/buy/cylinder-head-box-spanner-1-4-whit-both-ends_540.htm
who ever put this bolt in was a nutter because the bolt was the right size but they had put a big washer under it so when it was tightened the washer pulled down in the hole and curled round the bolt head leaving little room to get a socket on .
