Hi there
i wonder if you can help. I have recently bought a 1975 mk3 however on the right hand handlebar switch the small plastic knob to switch the lights on is missing,just the plastic bit everything else is there do any of you know where i might get one or anything that i can use as a substitute.The part just seems to be a push on part on to a small metal spade
hope you can help. regards Steve.
The Mk III switches are co…
Previously mike_sullivan w…
Previously mike_sullivan wrote:
The Mk III switches are cosmetically the same as the T140ES, there are Sparx repro's (& a NOS listing on ebay at the minute) - a quick google search shows that both left & right Sparx versions seem to be available again.
You may be lucky & someone may have one lying aroundthat they can let you have. If not you'lleither have to whittle something up, or scour the autojumbles looking for something similar. The left & right switches are identical &both aresecured by a smallx-headscrew inthe left face of the switch.
My own grail is that I'm trying to find a spring & ball bearing for the indicator switch after my late father 'helped' me by cleaning the contacts!
Mike, MK III
Many thanks Mike i will give that a try
kind regards Steve.
Hi Steve - if you email me…
Hi Steve - if you email me your address using alsesh@aol.com
I will mail you a spare plastic knob that I have - Alan
Previously stephen_udall w…
Previously stephen_udall wrote:
Hi there
Hi Steve,
Is there anything in the picture that is useful to you. I know it's the wrong side but maybe the buttons are the same. If so you can have it as it is of no use to me,
Regards Rob.
Attachments dsc01648a-jpg- Log in to post comments
Hi Steve, Is there anythin…
Hi Steve,
Regards Rob.
Hi Rob,
The MkIII is completely different.
Previously alan_sessions w…
Thank you so much Alan for your help
regards Steve.
Previously robert_gittins…
Hi there
Hi Steve,
Regards Rob.
Thanks Rob for your reply Alan found one for me what a result
regards Steve
Mike, MK III
Mike, Andover Norton have just sent me their newsletter for this month, and I noticed that they now do a Lucas switch repair kit number 13.1657, or 1656 depending on the year of your bike, for about £15.95 + vat
Don't know if that's what you are looking for, but it's got springs and ball bearings included. May be worth a look?
Tim MK lll
Hi Tim, yes I noticed that…
Hi Tim, yes I noticed that & wondered if it would work. The kit is actually for the earlier switches, I was saved from experimenting by Alan who kindly sent me the required parts!
Mike, MK III
