Layshaft bearings
Despite looking hard I am unable to determine what is the difference in width between the normal ball race and the roller bearing that is often used.in the back of the case.I'm not looking for advice ,just measurements,thanks.
Hi Robert
The FAG Roller Bearing Reference NJ203E TVP2.C3 dimensions are as follows: Bore - 17mm, O/D 40mm and Width - 12mm; ie. the same as the single row bearing used on the wheels.
Derek Ambler
Mick Hemmings advised using ball bearing 6203 TB which has a higher load bearing capacity (extra balls - if you don't mind me saying so!). However I've always used the roller bearing to no detrimental effect that I'm aware of.
If you can get it you may find the NF configuration of the roller bearing to be easier to extract because the rollers come out with the inner just leaving the outer in the gearbox case. It's a bit easier to use a bit of leverage behind the bearing rather than having to sideways lever on the rollers if the bearing doesn'tdrop out of the heated gearbox case when you come to try to remove it at some future date. Being in a blind hole it can be a bit difficult to get the bearing out, I use a suitably sized and ground off coach bolt head to provide a bit of encouragement to a stubborn bearing
One of the things I find difficult to understand is why its necessary to shim the layshaft for the roller bearing and NOT the ball bearing(although rollers do need to be contained),especially when we are told that the ball bearing needs to be a hand fit to the shaft,unless the ball bearing is wider than the roller. Then it makes sense. Except then we should be shimming between the roller and the fixed gear,and not behind the kickstart.In any event If the bearings are the same width and a hand fit it makes no difference and the shaft needs shimming in both cases. Mine certainly needs it with about an 1/8th of an inch of end float which has allowed things to get knocked about.And no the kickstart bush is not worn .I'm thinking of making up 2 equal shims, one to go in the kickstart shaft against or behind the bush and one against the roller. What do you think??.
I don't think you should need to shim the layshaft for either the ball race or the roller.
As for 1/8th inch end float, how are you measuring it with the kickstart shaft fitted? If there is 1/8th inch end float there must be something seriously amiss if you look at the attached section through the gearbox. The layshaft endfloat appears to be controlled between the inner race of the ball/roller race, the width of the 1st gear and the flange of the kickstart bush.
Cheers Jim
section-norton-gearbox-jpg
Thanks James for the section detail. The only way to measure end float is with the Ks shaft and inner cover installed.The area that gives me concern is the junction between the third gear free pinion and the second gear ,at this point any axial loading from the shaft to the 3rd pinion is carried on a tiny area of the 3rd from the splined end of the shaft.,the bronze bush of the 3rd is also undercut with an annular recess at the ends(for lubrication?) which means it can't help.My gear has suffered here.There should not be much axial loading but any impact on the KS shaft (intentional or accidental) ends up here.I am also curious about the fit of the fixed pinion at the end of the shaft against the 3rd gear, in my case this has to be driven on with a hammer and socket but with care to avoid trapping the 3rd gear.Is this normal?.I also need to check the bush in the KS shaft ,althogh no symptons of wear it appears too short.
Hi Robert
It sounds like your layshaft 3rd gear may be damaged. You're right to say that there is only a tiny area of the splined layshaft in contact with the 3rd gear, but it should be sufficient to deal with any axial loads as they should also be tiny if any. See attached photo of one of mine, you can just about see a slight contact witness mark.You say that any impact loading on the kickstart shaft would end up there, but if you look at the section detail, any end loading should be transmitted through to the layshaft bearing, but in practice this shouldn't happen unless someone takes a hammer to the end of the kickstart shaft!
The fixed 4th gear pinion at the end of the layshaft is normally a nice tap on fit with a rubber mallet. When fitted I check that the 3rd gear pinion rotates freely with no end float.
The bush in the kickstart shaft could well be another issue if the bush flange is not the correct thickness to control the layshaft endfloat.
Hope all this helps
Jim
img_2086-jpg
Hi Jim, Mine looks like yours!( so much for tiny axial loads!), But I notice that your bushes are not undercut at the ends, Does this mean they are meant for somewhere else?.They look better for thejob.
Hi robert, I don't understand?
As for the floating bush, I'm pretty sure that it's an original from the factory.
Robert, You're not thinking that the machined recess on the end face of the 3rd gear is wear are you? The actual contact area is a tiny amount of polishing which is bearly visible
Hi Jim, No I was not thinking that. I was looking at the small nicks in the end of the gear I have a few extra ones, some may be the end of the oil scroll,but i have a few extras. The Box is back together ,after fitting a few new parts, I was left with 71 thou end float,I used a 50 thou spacer between the roller inner race and the fixed pinion and a 20 thou shim behind the kickstart. I have finished up with 1 thou end float,A bit tight!. The box works ok though I'm wondering if the selector fork has enough play to not be in continuos contact.I may strip it again to reduce the roller spacer. I'm sure these boxes must run normally with about 50 thou end float,which is probably concealed by the layshaft being a bit tight in the std ballrace in the back of the case.
Back together and working, the change is still not the "knife thro butter" we hear about. But i can now get neutral at a stop.Its a bit stiff at times through the gears so I'm thinking of looking at the cam plate plunger and spring next.
