Hi. Can anyone i.d. this crankshaft flywheel. (see attached images). I'm confused by the part no. (064263) which i can't find in any of the usual resources. Also the cut away to the mass at the bottom of the flywheel is to much tighter rads than most that i have seen via google searches. More typical is as per https://goo.gl/images/1eYRRgAny ideas/ comments appreciated. Thanks.
flywheel-jpg
Part numbers changed as th…
Part numbers changed as they went through the production process, the part stamped on the part could be up to 2 or 3 away from the final part number, so look for the closest number.
