Hi, just wondered what people are running gearing-wise.
I have a 1972 750 Roadster, and I was thinking of 19 or 20 teeth (from the Tech Digest)- but maybe it will be undergeared with 19?
I don't intend to tour, mainly running around for fun, mostly backlanes/ A roads. It has a std 42 tooth rear sprocket, 19" wheels, PW3 cam and has been balanced.
Thanks very much
Robin
I had a '72 Commando 750.…
I agree with John. When I…
I agree with John. When I first had my Commando back in 1975 it had a 19t sprocket on and accelerated like the clappers. I have a 22 on now which gives 70 MPH at about 4200rpm. (twin Jim Schmitt flatslide carbs and a pw3 cam) The mistake I made at the time was to have the ports opened up to 32mm, 30mm is the way ahead for a slick 750 on the road. The original Interstates were fitted with a 21T sprocket as standard for touring.
MyMk3 850 had a 20T g/box…
MyMk3 850 had a 20T g/box sprocket fitted when Igot it from the Kenya police - geared for good acceleration on presidential motorcade duties, but found it not good fornormal road workespecially on thelonger journeys with sustained high revs at cruise. Changed to a 22Twhichprovided much more practical gearing.
Thanks, I've gone with a…
Thanks, I've gone with a 20 tooth (well 18 actually to go with the Maney belt drive).
I hear the Jim Schmitt flatslide carbs are good (my brother has a set too), but I see he's stopped selling them now. I'll keep the ports at 30mm.
I had a '72 Commando 750. When purchased, it had been fitted with a 24 tooth gearbox sprocket, which was far too large. I changed down to 22 teeth, which was far better, and was fine for road use, however too high a gearing to obtain max revs in top gear. Probably a 19 tooth sprocket would result in better acceleration, but too high an engine speed (and fuel consumption) for fast cruising. A 20 tooth is probably the best compromise.
