Exhaust port repair
I am planning to mill out an exhaust port on a 750 head to weld in a fresh thread. In trying to determine the centre of the exhaust port (vertically), I noticed that the 4th fin up from the bottom seems to line up perfectly with the vertical centreline. Has any one noticed this lucky coincidence or am I wrong? This would make it relatively easy to clamp the head down in the mill, locate the centre and clean out the thread area.
Is there not enough metal in there to do a helicoil repair? I had mine helicoiled 38 years ago as recommended by Norton themselves and it's worked fine. I can tighten my exhaust nuts with gay abandon. I would be reluctant to carry out any welding repair if I could avoid it as the localised heat and distortion would require further attention. The guy who did it was in Croyden and used to feature in MCM tuning a 500 aircooled Suzuki, Ernie or Eddie .......Hall maybe?.......... seems to ring a bell but it was 38 years ago I suppose he had the giant tap and inserts to do the job.
It was Ernie Hall, Steve Maney does a alloy threaded insert repair for £99 +vat for both sides. No welding involved
Mick Hemmings did mine and welded an alloy insert in, the first repair which was a bronze insert shrunk in became loose.
Unfortunately there is no budget for paying a professional to do this job. I am trying to break the job down into simple enough steps that I have the skill to do. This includes very basic lathe work, mill work and welding. Both ports had welded-in inserts already and one has stripped for at least the 3rd time. At least I know how to prevent them stripping or rattling loose ever again.
