Hello,
Is it possible to remove the clutch centre from the gearbox mainshaft without having to remove the whole clutch chainwheel ( and thus the primary chain and alternator)? When I try to pull the centre it wants to bring the clutch chainwheel with it. And the exploded parts drawings are not quite clear enough to show how they are attached.
You have to remove all the…
you will find a posting by…
you will find a posting by me a couple of weeks ago on this section having the same problem, I wished to replace the clutch centre as the one installed was pretty grim and rusty, I had to remove the whole perishing drive chain, the sprocket just didn't want to play and on examination one of the puller threads had been stripped previously, eventually I had to replace sprocket, clutch inner and I purchased a RGM bronze conversion following advice from a Gommando guru on here, piggy bank is still trying to get over it!!
Just wonder why there is a circlip at the rear not come across this before and it is held on to the main shaft by a locktabbed nut, kind regards
You have to remove all the stuff.
The clutch centre is fixed with a circlip behind the ball bearing.
(Part No 52 on the drawing) Therefore you cannot pull it.
https://andover-norton.co.uk/en/shop-drawing/237/chaincases-chains-sprockets-clutch-alternator
