Prepping bike for run tomorrow, noticed fluid around the front brake lever pivot, more than a sheen, but definitely moist! Should I be overly concerned? (stock mk III disc with braided cables)
It looks like amaster cylinder rebuild may be in order - this was not in the Rimini prep schedule
Has anybody experienced anything similar & can suggest the likely cause.In the meantime I will investigate refurb kits.
Eeeee, there's always something!
Mike, Mk III
Any leaks are not good but…
Any leaks are not good but a leak at the master end can result in total failure.
