I've recently taken on a 1958 Dominator 600. It replaced a Triumph Daytona 955i which was a bargain and worked brilliantly but was too fast for my needs (national speed limit broken at 40% performance) and the riding position made it uncomfortable over any distance. Apart from the great engine, suspension and brakes, it had very good mirrors. The Norton has no mirrors - do people fit them and do they work on an old vibratory twin?
How can you tell if some mirrors will work for you on a particular bike without fitting them - my 1986 Yamaha 600 has them but no amount of adjustment gives the same view I had on the Triumph - may be the upright seating position has something to do with it?
The only morrors I would…
Another vote for Halcyon.
I have Halcyon bar end mirrors on 3 bikes now, and as Robert says they just work. I think mine are the 830 type.
Remember the old phrase "the quality is remembered long after the price is forgotten".
Image clarity is OK up to around 80-85mph on the Norton, then the vibes start interfering.
Regards,
George
I've got an Oxford bar end…
I've got an Oxford bar end mirror, stands up to the vibrations of a 500 single! But watch out not all bar thicknesses are the same.
Dan
hello, on my 500 single. …
hello,
on my 500 single.
after trying one or two cheap mirrors, none would stay put. some would fly off in the wind no matter how tight they were. at certain rev you slowly got a view of the tarmac when they vibrated loose. on fitting some raised handle bars i wondered if i could fit an old set of mirrors i had. they were off a triumph adventurer 900. its the sort of mirror you can grab hold of to push the bike around with they are fairly sturdy. dont know what view you would get on straight bars. i think its worth as already mentioned buy some dearer types, better quality ones.
barry
Thanks for the comments…
Thanks for the comments. Looks like I'll need to confirm the bar thickness first. I take it that it is the inner diameter that I must measure - I can't just measure the outer diameter and work down from there?
Good vibrations
Only old English bike I have where rear view isn't blurry is a Vincent with bar end mirror. All with long distance between mirror and handlebar gives blurry vision.
Mirrors
I use stadium or halcyon bar end mirrors on my dommi. Avoid the cheaper mirrors they do not give a very wide view giving potential blind spots. I suffered from vibration on my mirrors which became a blur after 30mph. Filling the bars with molten lead reduced the shake. Also I discarded the steel expander within the bars and replaced it with suitable sized rubber pipe. I now have good vision up to 50mph.
Thanks for all the comments…
Thanks for all the comments. I have viewed the Halcyon mirrors on Amazon. The only real issue I see is that they can get knocked when putting the bike in the garage.
I hope to take the bike out this week end for a short run and see how it holds together generally first of all - it has obviously been restored in the last 10 years but doesn't look like it has put many miles on since. I have a feeling the front brake hasn't bedded in yet although the rear brake feels powerful. I'm booked in to show the bike at the Banbury Steam Rally this June which is quite local to me.
They flip in. I sometimes…
They flip in. I sometimes do it in heavy traffic.
Yes measure the inside…
Yes measure the inside diameter and check they'll fit yours, i tried making a sleeve but it didn't work well, they kept slipping.
dan
I took the bike out over the…
I took the bike out over the weekend - how vibratory should these be - is blurred vision at higher revs normal? It seemed otherwise very stable and a good riding position and easy to handle at low speed when threading past oncoming cars - like an M21 but with more go.
Atlas good up to 55 mph.
Mark, My Atlas was very smooth up to 55 mph. Smoother in fact than my Airhead BMW!
I had two Halcyon bar end mirrors that were very clear up to 55 as well. after that the vision got blurry very quickly.
Worth paying extra for genuine Halcyons.
hello , makes you wonder…
hello , makes you wonder if a small adjustable weighted clamp on the stem would make a difference. so that you could move it up or down the mirror stem, to change the mirrors resonant frequency at a certain rev.
i know, i banged my head this morning. barry.
On my first ride my eyeballs…
On my first ride my eyeballs wobbled so much at 50mph that I couldn't see where I was going. Head steady bolts were loose. Huge improvement after they were tightened.
Your 99 ought not to vibrate uncomfortably.
That was vision blurring…
That was vision blurring without looking in mirrors ..
Unless there is something…
Unless there is something very wrong, it sounds like loose head steady. A loose steady causes such severe vibration that it can apparently damage the frame. It's not accessible without removing the tank.
I removed the tank and…
I removed the tank and discovered that although the cylinder head steady was securely bolted to the frame with nylocs, it had movement at the cylinder head bolt - there was one big washer on top but nothing to take up the slanting space between head and bracket. I put a big washer in for now and tightened things up. Should there be some rubber bushing in there?
Just bolted solid. No…
Just bolted solid. No rubber involved.
With the top bolt tightened…
With the top bolt tightened it is less vibey than before. Looking at other pictures of the mount it seems the top mount should be sitting flat on the head, not at an angle as it is on mine. I'm still taking it easy on the bike, not exceeding 50 mph, as I know it has extensive work but have no idea of how much it has been used since the last rebuild due to a non functioning odometer (if that is to believed then it has done 6 miles since last MoT..)
Do you have the standard…
Do you have the standard stay? It has a twist at the lower (head) end, where it flattens out to sit onto the head. If it's at an angle, surely there must be a triangulat gap? That won't do it or the stud any good. All the load should be carried by friction between the surfaces of the stay and the head - the stud makes sure they are tightly held together. A picture would help.
Back to the original question......
....I fit one of these mirrors to my '48 Inter and couldn't have been more pleased. Expensive but very well made, unobtrusive, and nicely adjustable.
https://www.oberon-performance.co.uk/adjustable-mirrors/adjustable-mirror
I visited Daventry…
I visited Daventry Motorcycle festival today (on the '86 Yamaha as the Dominator has been undergoing adjustments recently) and saw a good selection or bikes and mirror options. I'm now thinking that a bar end mirror would give me issues where I store the bike - I tend to put the Norton on the right of the small garage and the Yamaha on the left on side stand to give more room to access the Norton. What ever I eventually fit, I don't think I will go this far ..
I bet the owner wore a knee…
I bet the owner wore a knee length Parker with a hood and covered in graffiti, with the scooter hiding a rattle can air horn behind the right leg shield!!
I wondered what happened to Barry Vasey from all of those years ago.
round or oblong?
Do people recommend the round bar-end mirror or the oblong one?
The only morrors I would consider are Halcyon made in stainless with an expander that works and wont fall to bits , replacement glass on line ,and semi concealed adjusters to stiffen the action . Worth the money but not cheap compared to Chinese crap.
