Hello All
I have recently purchased Norton Dominator 88 1960
Bike hasnt been on the road since 1970
Oil changed, new plugs new battery new exhausts few blown bulbs replaced
Bike runs well on low revs but engine doesnt pull when throttle opened just seems to bog down
Cleaned the carb but not fitted new points bit unsure of how to TBH
Ticks over nicely and ok up to certain revs
Any ideas would be much appreciated
Thanks Rick
{newbie norton owner}
Take out a spark plug and…
Taken plug out appears to be…
Taken plug out appears to be dry and a bit sooty
Auto advance.
Hi Rick,
If your bike has been unused for 50 years, it might be that the auto advance mechanism is seized in the closed position so the engine is running retarded at higher revs.
Hi Richard Thanks for info…
Hi Richard
Thanks for info unknown territory for me
But will have a look
Thanks for reply
You can check the adv/retard…
You can check the adv/retard unit is free by removing the distributor cap and gently turning the rotor arm which should spring back under the action of the Adv/ret springs. Not so easy as it sounds as the lower cap spring clip is innacessible underneath and the carbon brush in the cap is delicate. I use a screwdriver on the cap clip and leave the brush alone if its free to spring in and out. Sounds more likely you have a worn 106 needle jet or the needle is a notch too high in the slide. Needle jets have a short life and have been known to wear out in 1000 miles. Avoid E-Bay offerings.
bogging down
It would also be a good idea to check if the carburettor is clean. There are various tiny passages which can become blocked. On my bike I had an off-idle stumble, which reduced but did not disappear when I enriched the idle mixture and raised the needle. It turned out to be a compensator hole down-stream of the jet tube. At different stages it passes air and also fuel. I cleaned it carefully using a tiny piece of wire, tweezers and a magnifying glass.
Robert....
Can't agree that the needle jet could be worn unless it is a concentric carb. It should still be a mono-block, which do not wear a fraction as much. Also if it was running rich (worn jets/needle wrong position) then would actually accelerate quite well, until it fouled the plugs. The idea that the ADV/RTD is stuck is favourite and an easy check. Of course it could turn out to be a magneto!
We don't know anything…
We don't know anything about the carb you have ,or how old it,and its parts are or whether they are correct . It is worth doing the simple easy stuff first , but if nothing obvious turns up then you are going to have to read up and learn the hard way!. Its always usefull to do one thing at a time and check progress. Sometimes you can pinpoint the issue to carburation or ignition ,if so this helps enormously as it halves the things to work on and reduces the chances of making it worse by fiddling with things that are fine. With a bike as old as this there can be corrosion in any connection which can weaken ignition to a point where it gives up under load.
Help!!
Thanks for all replies
Further investigation distributor cap off and rotor arm does in fact spring back when turned slightly
Nice strong spark also
Should i be recleaning carb again and renewing main jet
Bike just dies on accelaration then picks up again on quarter throttle
Rick
I think you need to go one…
I think you need to go one step at a time. If it was my bike I would suspect the auto advance being stuck in the retarded position as that best matches your described symptom . If you are unsure how to check it ask for help from someone that is familiar with how it works as its difficult doing it based on written advice, Youtube is generally a good source for a visual aid. Once that has been checked and if the problem persists go on to the next most likely cause. If mechanical is new to you I would suggest not to start dismantling the carb but to get help from someone that is experienced. Good luck with it.
Most unlikely to be the…
Most unlikely to be the main jet as you don't get much use of it at the throttle opening you are using . Could easily be restricted fuel supply , Filter in tank, filter on carb, air breather in tank cap. Water in main jet well. Phase seperation of EO5 fuel.!!
Good point David...
I was just about to say run it up to the revs it starts to fumble then close the choke a little so see what happens. IF it improves you are running lean if, it dies you are rich. If nothing changes check the choke slide is moving. If its starting and running your primary circuits sound good. When you transition onto slide and needle you falter then one or the other is giving you a false mixture.
Tight cable for choke OFF!
Water in main jet well...
Another good option on this one. I have had this syndrome on other set ups/carbs time and again you rev it to clear it but it never does. Selected us of an air line has been successful. Other wise you have to strip the carb-again. Too much use of a water hose near a running engine can cause this especially under the cars bonnet.
Thanks William wise words…
Thanks William wise words indeed
Appreciated
Rick
Not knowing what an air…
Not knowing what an air slide is could be the problem . Commonly called the choke, Normally controlled by a handlebar mounted lever. If left partially closed will give the described symptoms. Its a bloke thing not to read the instructions or users handbook. I do it all the time, would be a nice easy fix if thats all thats wrong.
Bogging down part two
Evening all
OK here we go
Fitted new amal carb all went well
On start up ticks over nicely when air slide is up revs rise dramatically
Any ideas
Not sure if we are talking…
Not sure if we are talking at cross purposes here but I find the terms air valve and air slide to very confusing and have always called the lump of cylindrical metal in the carb - that causes the revs to rise and and fall - the throttle or throttle slide. The other lump of rectangular metal - that causes the mixture to go rich - the choke or choke slide.
So, is it the raising of the choke slide that is causing the revs to rise or the raising of the throttle slide?
Amal use term "air slide" …
Amal use term "air slide" (for the 'choke') and "throttle slide" (for the bit that makes it go faster).
If tickover "rises rapidly when air slide is lifted", note that tickover speed is only relevant when engine is warm and air slide is up. I don't think I ever leave it down for more than a couple of seconds...some people remove them (and seal the hole on top).
Hi Bob it's the opening of…
Hi Bob it's the opening of the air slide ticks over when closed revs rise when opened
Rick
I'm not sure why you are…
I'm not sure why you are concerned about how it runs when cold. All internal combustion engines run best when warmed up. I open the air slide as soon as it fires up. I suppose if I want it to tickover from cold while I put my riding gear on, open the gate etc then it might be necessary to use the slide but that's all. The only question I asked was whether you are running with it closed? If so, it will be far too rich and will bog down. If you do open it as soon as the bike starts then your problem is elsewhere.(You might need it at the first traffic light stop when very cold...but that's for you to find out)
Sound like some basics need…
Sound like some basics need to be set. There should be a little slack in the throttle cable when the throttle is closed . To start setting up the main slide (controlled by the throttle) needs to be all the way down with the throttle closed ,and not held up by the idle speed screw . Put your finger in the intake and check that the idle speed screw is far enough down to be not moving the slide, Then raise the screw till you feel it move the slide .now screw it in a whole turn .start the engine ,use the throttle a little if needed , Adjust the screw to give an idle. With the engine warmed up well you can follow the idle tuning instructions. The choke slide needs to be fully up . There is also a possibility that the choke slide is somehow picking up the throttle slide as its lifted.
Rick, if the bike hasn't …
Rick,
if the bike hasn't been on the road since 1970, are we talking about a barn-find type scenario?
If so, I would advise you not to worry too much about carburation until you have stripped and cleaned out the sludge trap in the crankshaft. I have found these sometimes to be completely full and if the sludge has dried out during hibernation it can break up and block the big-end oil ways, especially if a modern detergent type oil is put in. Old 'straight' oils produced a lot more sludge than modern oils and I have seen two 'time capsule' type bikes, a 99 and a BSA A7SS with their engines completely wrecked a few hundred miles after coming out of storage, so, personally, I wouldn't risk it unless I knew it was definitely clean.
The ECU is not fitted to…
The ECU is not fitted to these bikes, the carb is tuned for best running on a warm engine only, the choke is there for the purpose of covering up the mixture being wrong for a cold engine and the rider is the ECU and has to control the choke manually combined with tickling of the carb.
CHOKE?
The choke in ALL bikes and cars from this era is a necessary item. When cold the petrol engine needs a rich mixture to initially, start that is why we 'tickle' it and 'choke' it. Once started and beginning to run the 'choke' can be reduced or removed completely. Any one who finds he can start without choke is running an engine richer than needed. David and Robert above have it right.
88 bogging down
hi Rick
Just a thought, I had a similar problem with my AJS a while ago after a long lay up and I assumed it was a carb problem, but after extensive work on the carb I switched to an electrical fault, it behaved very similar to yours, but wouldn't rev when under power.
Eventualy found the problem was the condenser!.......I replaced it and all problems solved. Is yours mag or coil?
Regards John O
Hi John Bikes coil think…
Hi John
Bikes coil think you could be onto something I have replaced the carb and still have the same symptoms
Rick
Hi Rick The condenser is…
Hi Rick
The condenser is very easy to test, and change If required, keep me ( and others) informed of your progress
Regards John O
Hello All Update After new…
Hello All
Update
After new carb not sorting problem out reverted to the original,cleaned again raised the needle by two
Happy to say bike is on the road just been out for my first proper run and not had to push her back home
Very happy like to say Thanks for everyone's input
Happy New Year to all
Rick
Thankyou Rick for updating…
Thankyou Rick for updating us. It can be a thankless task trying (often in vain!) to diagnose a fault from a few lines of script. Its also very easy to forget just how clueless WE were when we first got our fingers dirty on these old mangles .
what is the new carburettor setting?
The new fuels are different from old ones which the Amal carburettors were set up for. What jet and needle position have you settled on?
cleaning sludge traps
In the mid '80s, I bought a BSA Super Rocket which had sat idle since at least the early '70s. I took a big risk, fitted a Commando oil filter plate and ran high detergent diesel oils. The bottom end stayed very happy. I guess I was lucky. Actually, the bottom end was the only part of the bike I didn't dismantle and rebuild. What a pile of trouble it was, and then solid and reliable once I sorted it. Actually, I regret selling it - but it did fund my current long term project, a total basket case Rapide.
Replaced with original carb…
Replaced with original carb after dismantling and another thorough clean lost count of how many times .....see attached the one I have as a spare I bought from burlens
I can't remember, but have…
I can't remember, but have you checked valve clearances? If they are too tight they can close up when hot and one or other valve might not close. Result is that it might well carry on running very badly (although it's unlikely to re-start until it cools a bit).
Take out a spark plug and describe its condition.
